Plasma module simulation error "Division by Zero"
Posted 15 set 2019, 01:20 GMT-4 Plasma Physics, Parameters, Variables, & Functions, Studies & Solvers Version 5.4 0 Replies
I downloaded the capcitively coupled plasma simulation file from the following web: https://www.comsol.com/model/gec-ccp-reactor-55011
The only change I did was changing the geometry and mesh to suit it. But I get the following error, Could someone help me with this, please The simulation file is here: https://drive.google.com/file/d/1Odik5nPlgyy7xPLaWrcYifVTMhcFiD8F/view?usp=sharing
The error,
Division by zero. - Function: / Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.ptp.Te@VDN$comp1.Ne_per - Defined as: (3(exp(comp1.Ne_per)(1/(unit_m_cf^3))))((-(2comp1.ptp.en))/((3comp1.ptp.ne)^2)) Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.ptp.nue_th@VDN$comp1.Ne_per - Defined as: (0.5((((8e_const)comp1.ptp.Te)/(pime_const))^(-0.5)))(((8e_const)((3(exp(comp1.Ne_per)(1/(unit_m_cf^3))))((-(2comp1.ptp.en))/((3comp1.ptp.ne)^2))))(1/(pime_const))) Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.ptp.ne_bnd@VDN$comp1.Ne_per - Defined as: ((comp1.ptp.ne(((-0.5)(1-comp1.ptp.re))((0.5((((8e_const)comp1.ptp.Te)/(pime_const))^(-0.5)))(((8e_const)((3(exp(comp1.Ne_per)(1/(unit_m_cf^3))))((-(2comp1.ptp.en))/((3comp1.ptp.ne)^2))))(1/(pime_const))))))+((((-0.5)(1-comp1.ptp.re))comp1.ptp.nue_th)(exp(comp1.Ne_per)(1/(unit_m_cf^3)))))(1/(1+comp1.ptp.re)) Failed to evaluate expression. - Expression: d(d(((2(comp1.ptp.ne_bnd+comp1.ptp.tne_bnd)test(comp1.Ne_per)pir)(ptp_xdim.atonly(dvol)))(dvol_spatial),{test@7}),comp1.Ne_per) Failed to evaluate Jacobian of expression. - Expression: d(((2(comp1.ptp.ne_bnd+comp1.ptp.tne_bnd)test(comp1.Ne_per)pir)(ptp_xdim.atonly(dvol)))(dvol_spatial),{test@7}) Failed to evaluate Jacobian of expression. - Expression: ((2(comp1.ptp.ne_bnd+comp1.ptp.tne_bnd)test(comp1.Ne_per)pir)(ptp_xdim.atonly(dvol)))*(dvol_spatial)
Hello Indula Munasinghe
