24 nov 2011, 16:47 CET
the at() and with() and a few others are pure postprocessing operators (it's mentioned in the doc) not to be used in the solving process
One way around I have just tried in another case is to run a first simulation, then extract the results to a txt file, that I upload into a "int() interpolation function and use in a second simulation run. but it's all manual and slightly cumbersome
In v4.2a there are several new operators, take a close look into "operators" in the help files I havent had time yet to study all these new goodies
28 nov 2011, 18:06 CET
Dear Ivar,
there is indeed a new operator which is timeavg(...), and which does exactely what I want, but again, it is written, that the timeavg operator can only be used during results evaluation, so it should not be used when setting up the model.
Is there an other way to implement a moving average and be able to use it as in INPUT?
thanks
Alain
Dear Ivar,
thanks
Alain
29 nov 2011, 07:51 CET
not really then, but perhaps you can re-express your equations by adding a new variable and integrate that one, hence getting something as a time average
