Point value in 3D Geometry
I am working with 3D geometry(Heat transfer module) and
i want to know the point value.
Can I define x, y, z value in results table?
Because there was a problem defining point at geomtry
I want to avoid defining point as geometry.
Can you help?
1 Reply Last Post 23 nov 2011, 12:43 CET
Posted: 1 decade ago 23 nov 2011, 12:43 CET
you can define a point in the geometry (not sure if a single point is accepted, it might have to belong to a valid boundary or edge, it was so in the early V4 versions). But anyhow, you can always:
Solve, right click the Data Set and add a 3D point Data Set, give its coordinates and then "point process" (plot) the data-set resulting from this data extraction
Hi you can define a point in the geometry (not sure if a single point is accepted, it might have to belong to a valid boundary or edge, it was so in the early V4 versions). But anyhow, you can always: Solve, right click the Data Set and add a 3D point Data Set, give its coordinates and then "point process" (plot) the data-set resulting from this data extraction -- Good luck Ivar
