Problem on Parametric sweep
I have a problem on parametric sweep. I have two electrodes on a block by which to inject a current. I would like to vary the distance between the electrodes, but i lose the reference current on the electrode.
How can I fix it?
I hope i was clearly and i hope in your response.
Thank you so much.
Chiara
1 Reply Last Post 17 nov 2011, 13:19 CET
Posted: 1 decade ago 17 nov 2011, 13:19 CET
if you make a full parametric sweep (outer loop, not a "continuation") then you can drive your geometry with the parameter that could be deciding on the electrode distance.
Note that in this case each simulation start from original initial conditions, you do not use previous initial conditions as starting point for the next seep value
Hi if you make a full parametric sweep (outer loop, not a "continuation") then you can drive your geometry with the parameter that could be deciding on the electrode distance. Note that in this case each simulation start from original initial conditions, you do not use previous initial conditions as starting point for the next seep value -- Good luck Ivar
