Visualization of particle tracing results in non-flat surface
Posted 25 lug 2019, 05:25 GMT-4 Particle Tracing for Fluid Flow, Porous Media Flow, Results & Visualization Version 5.3a 0 Replies
I have a 3D hydrological model which I have used Darcy's Law to do the groundwater analysis. Then I used Darcy's law results as in Partcle tracing for fluid flow. My model has 3 different layer with different hydraulic conductivity and prosity values. I want to release the particle from a flat surface in my bottom layer and trace the particle to their final destination. Finally, I would like to get the particle tracing results on different layers' top surface (which are non flat). Let explain it more in detail with a simple model (attached file): in the attached model, I would like to realease the particle from the horizontal surface at 2 m and get the particle tracing result of the particle that reach the top surface (for example particle position in z, or particle velocity, ...) at the non-flat surfaces wich are located around 4, 6 , and 8 meters! So far I could get just the results on the top surface (non flat surface located around 8 m); but I was not able to get the the result for the non-flat surfaces at 4 and 6 meters It will be really appreciated if you could help me in this.
Bests, /B
Hello Brian Mojarrad
