How to save large fem structure into .mat file
Posted 14 nov 2011, 17:10 CET Results & Visualization Version 3.5a 10 Replies
When I tried the 'save filename.mat fem' command in COMSOL with Matlab R2010a, the error is as below:
java.lang.OutOfMemoryError:Java heap space
Then I changed the default heap size parameters from 256m (default) to 2g.
I also tried -v6 -v7 -v7.3 before the command line.
The size of the fem structure is about 2g.
I even tried to divide the structure, but it only works for scalar structure.
Since none of these works, I still could not save the fem structure in my simulation.
If you have any ideas or comments, it will be greatly appreciated.
Here is my fem structure looks like:
version: [1x1 struct]
meshtime: 'TIME'
appl: {[1x1 struct] [1x1 struct] [1x1 struct]}
sdim: {{1x2 cell} {1x2 cell} {1x2 cell}}
frame: {'mesh' 'xy' 'ale'}
shape: {1x13 cell}
gporder: {[4] [30] [2]}
cporder: {[2] [1]}
sshape: {[1x1 struct] [1x1 struct] [1x1 struct] [1x1 struct]}
border: 1
form: 'weak'
equ: [1x1 struct]
bnd: [1x1 struct]
pnt: [1x1 struct]
var: {1x64 cell}
elemmph: {1x11 cell}
eleminitmph: {[1x1 struct]}
const: {1x12 cell}
draw: [1x1 struct]
geom: [1x1 geom2]
mesh: [1x1 femmesh]
xmesh: [1x1 com.femlab.xmesh.Xmesh]
sol: [1x1 femsol]
??? Error using ==> save
Java exception occurred:
java.lang.OutOfMemoryError: Java heap space
My workstation configuration: wins xp 64bit 32G RAM
memory
Maximum possible array: 21408 MB (2.245e+010 bytes) *
Memory available for all arrays: 21408 MB (2.245e+010 bytes) *
Memory used by MATLAB: 5612 MB (5.885e+009 bytes)
Physical Memory (RAM): 32765 MB (3.436e+010 bytes)
In Use: 13611 MB ( 352b90000)
Free: 19153 MB ( 4ad1cb000)
Total: 32765 MB ( 7ffd5b000)
Page File (Swap space):
In Use: 13766 MB ( 35c67d000)
Free: 21404 MB ( 539ca0000)
Total: 35171 MB ( 89631d000)
Virtual Memory (Address Space):
In Use: 8344 MB ( 209860000)
Free: 8380263 MB (7fdf6780000)
Total: 8388607 MB (7fffffe0000)
Largest Contiguous Free Blocks:
1. [at 4d0883000] 8366183 MB (7fa867bd000)
2. [at 3192e2000] 7028 MB ( 1b741e000)
3. [at 7ff7ffe5000] 2046 MB ( 7fe2b000)
4. [at 203df0000] 1593 MB ( 639a0000)
5. [at 198ed2000] 674 MB ( 2a2ce000)
6. [at 1c61f2000] 475 MB ( 1dbfe000)
7. [at 105690000] 375 MB ( 177e0000)
8. [at f5c91000] 206 MB ( cedf000)
9. [at 7ff58b4c000] 190 MB ( bea4000)
10. [at 1879e2000] 170 MB ( aa8e000)
8378946 MB (7fda4263000)
For example,
Structure_test
ans =
u: [3974351x60 double] (143204734 stored)
ut: [3974351x60 double] (0 stored)
reacf: [3974351x60 double] (115800 stored)
tlist: [1x60 double]
This structure has four field variables, u, ut, reacf, tlist. It appears to me that Matlab can't handle 2^31 sized elements or more than 2gb file size. Is it true?
I think if we can find a way to store structure_test.ut, this problem will be solved.
2Gb is typically 32 bit adress space (in theory 4Gb) looks like your are not fully 64 bit adressing compatible there. But with 3.5 I'm not that astonished, you probably need to upgrade to latest version on matlab AND COMSOL and perhaps PC for such large model ?
And even with a 64 bit OS, if you format a disk to FAT32, you have a file size limit between 2-4 Gb. Do not use that for your scratch disk
I am running a simulation using comsol 4.2 with matlab now to see if there is any changes.
However, I am still surprised that I could not save a 400M structure_test structure as below.
I have successfully saved a 1.5G structure (not exactly the same, but similar) before.
Too many variable in structure_test.u or structure_test.ut? But the total size is less than 1G.
Structure_test
ans =
tks
I have the same problem with saving file using save('file_name.mat') which is bigger than 300 MB. I tried to edit java.opts using the instruction on MatLab web page:
www.mathworks.se/support/solutions/en/data/1-18I2C/index.html
or Comsol support (LiveLink) on:
www.comsol.fr/support/knowledgebase/1092/
but both do not work. The most strange thing is that the computer has 132 GB RAM with 32 cores and 1 TB harddrive but Java still gives this OutOfMemoryError.
Really do not know what can I do!
I am working with Comsol 3.5a with Matlab R2010a on OpenSuse 11.3
probably it would work better in V4 where multi-core large (64bit) ram options have been further enhanced
thank you for quick answer.
But now I am confused what did you mean with the V4. Is it the version of OpenSuse (11.4) or I should use save command with '-v4' or is it some version of Matlab?
Also I changed the default option in File/Preferences/General/MAT-files to -v7.3 from -v7 so now it will maybe work better, I hope.
p.
You might try to install comsol 4.2 and use comsol 4.2 with matlab (comsol 3.5 matlab compatibility)
Then use save -v7.3 xx command to save
Let me know if this works for u
well, the Comsol 4.2 is installed on the PC but the script I am using is written in Matlab with commands from Comsol 3.5 and I have heard that strating with Comsol 4.0 the commands was changed very hard. This is the reason I am still using Comsol 3.5 Is there anythig which can help me with the translation of 3.5 scripts to 4.?
And I suppose that V4 in message from Ivar is then a version of Comsol, isn't it?
p.
Suggested Content
- KNOWLEDGE BASE Using Symmetries in COMSOL Multiphysics
- FORUM Saving Fem as *.mat
- BLOG Maximizing Eigenfrequencies with Shape and Topology Optimization
- KNOWLEDGE BASE How can I Migrate my Local Model Manager to the Database of a Model Manager Server
- BLOG How to Integrate External Data Files with Your COMSOL® App
