Problem with units
I want to use a density variation with concentration of the form:
rho=A*sqrt(C)+B*C^2
where C is in mol/m^3.
To supply the value of A i need to put units of m^1.5/mol^0.5
However, I am unable to do so as it gives errors.
Please help.
2 Replies Last Post 9 nov 2011, 04:02 GMT-5
Posted: 1 decade ago 8 nov 2011, 16:08 GMT-5
there is a few threads about that, there was an issue with fractional units in v4.0 (I belive its solved in later releases)
But the orange unit waring is only a warning, so long you put consistent values it will calculate and if you respect values correctly the results would even be correct. you do just not get the COMSOL verification of your units
Hi there is a few threads about that, there was an issue with fractional units in v4.0 (I belive its solved in later releases) But the orange unit waring is only a warning, so long you put consistent values it will calculate and if you respect values correctly the results would even be correct. you do just not get the COMSOL verification of your units -- Good luck Ivar
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 9 nov 2011, 04:02 GMT-5
COMSOL does not yet support non-integer unit exponents, so attempting an operation or declaration that results in such unit exponents gives a unit syntax error. One way to work around this in this case would be to define A^2 rather than A.
A_squared = <value of A>^2[m^3/mol]
then the expression A*sqrt(C) = sqrt(A_squared*C) gets a valid unit (dimensionless in this case).
But if you want A*sqrt(C) to be a density with the unit of kg/m^3, use
A_squared = <value of A>^2[kg^2/(mol*m^3)]
instead.
Magnus Ringh, COMSOL
Hi, COMSOL does not yet support non-integer unit exponents, so attempting an operation or declaration that results in such unit exponents gives a unit syntax error. One way to work around this in this case would be to define A^2 rather than A. A_squared = ^2[m^3/mol] then the expression A*sqrt(C) = sqrt(A_squared*C) gets a valid unit (dimensionless in this case). But if you want A*sqrt(C) to be a density with the unit of kg/m^3, use A_squared = ^2[kg^2/(mol*m^3)] instead. Best regards, Magnus Ringh, COMSOL
