How to asssign Conductivity to each element
Hello
i made the 2-D square model and make square Mesh elements . can i assign different conductivity to some of the mesh elements?
4 Replies Last Post 28 ott 2011, 14:42 CEST
Posted: 1 decade ago 28 ott 2011, 12:29 CEST
In COMSOL you do NOT work on the mesh (this is important to understand if you are used to "classical" FEM) you define the physics onto the elements (geometry) and then you mesh the geometry and the mesh elements inherit the physics required. So you should cut up your geometry first, apply physical properties to these "elements" (Domains, boundaries ...) and then mesh it and go on.
careful my naming convention here is the v4, it was slightly different in 3.5
Hi In COMSOL you do NOT work on the mesh (this is important to understand if you are used to "classical" FEM) you define the physics onto the elements (geometry) and then you mesh the geometry and the mesh elements inherit the physics required. So you should cut up your geometry first, apply physical properties to these "elements" (Domains, boundaries ...) and then mesh it and go on. careful my naming convention here is the v4, it was slightly different in 3.5 -- Good luck Ivar
Posted: 1 decade ago 28 ott 2011, 14:19 CEST
You can also define a spatially varying conductivity using piecewise functions with boundaries coinciding with the elements boundaries.
Nagi Elabbasi
Veryst Engineering
You can also define a spatially varying conductivity using piecewise functions with boundaries coinciding with the elements boundaries. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 28 ott 2011, 14:27 CEST
Thanks for the Reply.
i am not good in using COMSOL. what is did letme explain you again.
1) i make the 2D square model.
2) i Meshed it with square blocks.
Now the problem is i have one subdomain. and i have 16 Mesh elements, so what i want is to assign 4 of that elements to different conductivity and remiaining 12 to different.
Thanks for the Reply. i am not good in using COMSOL. what is did letme explain you again. 1) i make the 2D square model. 2) i Meshed it with square blocks. Now the problem is i have one subdomain. and i have 16 Mesh elements, so what i want is to assign 4 of that elements to different conductivity and remiaining 12 to different.
Posted: 1 decade ago 28 ott 2011, 14:42 CEST
Hi Adnan:
You should first think where the 4 different element is, then draw a geometry to represent it. Then add 2 different material property to corresponding domain. Mesh is the last step.
Vincent
Hi Adnan: You should first think where the 4 different element is, then draw a geometry to represent it. Then add 2 different material property to corresponding domain. Mesh is the last step. Vincent
