Buckling Analysis of Composite Plate
Hello everyone,
I have been tried unixal buckling analyisis of composite plate( for comparasion of Ansys results). But I guess failed some reason about boundary conditions, every time. In my scneraio, plate length (a) 100 mm, width (b) 100 mm. Each ply thickness 2mm and total thickness 10 mm, sequence of laminate [0, 90, 0, 90, 0], boundray condition simply supported (ss) and force: unaxial compression 10MPa. But I can't never set up exact boundary condition. In my knowledge (probably I'm wrong) Simply supported BC means, all edges are ''0'' in cartesian coordinate (x, y, z) system.
I used ''3D wizard>Strucutral Mechanics>Layered Shell(for physic)'' path for analysis in Comsol. Maybe this path wrong!
Please help me, thanks for all for attention.
1 Reply Last Post 22 apr 2019, 01:56 GMT-4
Pawan Soami COMSOL Employee
Posted: 7 years ago 22 apr 2019, 01:56 GMT-4
Hi Emre,
Simply supported boundary condition (on an edge) means, all displacements (u,v,w) are constrained and all rotations (thx, thy, thz) are allowed. In Shell based formulation, only constraining the displacements works however in Solid (or Layered Shell) based formulation, displacements need to be constrained at a specified position in thickness direction in order to allow the rotations.
In Layered Shell interface, in order to simulate Simply Supported boundary condition, you should use Fixed Constraint, Interface or Prescribed Displacement Interface. As opposed to Fixed Constraint or Prescribed Displacement, these boundary conditions allow the rotations and constraints only the displacement at the given position in thickness direction.
Alternatively, you can use Shell interface for modeling a composite plate using ESL theory. In this interface, you need to choose Layered Linear Elastic material for simulating a composite plate and the simply supported boundary condition is readily available.
You can contact COMSOL support for more details.
Best regards, Pawan Soami
Hi Emre, Simply supported boundary condition (on an edge) means, all displacements (u,v,w) are constrained and all rotations (thx, thy, thz) are allowed. In Shell based formulation, only constraining the displacements works however in Solid (or Layered Shell) based formulation, displacements need to be constrained at a specified position in thickness direction in order to allow the rotations. In Layered Shell interface, in order to simulate Simply Supported boundary condition, you should use Fixed Constraint, Interface or Prescribed Displacement Interface. As opposed to Fixed Constraint or Prescribed Displacement, these boundary conditions allow the rotations and constraints only the displacement at the given position in thickness direction. Alternatively, you can use Shell interface for modeling a composite plate using ESL theory. In this interface, you need to choose Layered Linear Elastic material for simulating a composite plate and the simply supported boundary condition is readily available. You can contact COMSOL support for more details. Best regards, Pawan Soami
