Question about COMSOL capabilities (need expert advice)
I have little experience with COMSOL but I did managed to do electrostatic simulations with rather complex geometries. I would now like to add fluid dynamics to these. Can I use COMSOL to determine the velocity field in a fluid as induced by the mechanical movement of a solid object?
For example, very simplified, I would have a glass filled with water and I let a metal ball drop. Can COMSOL determine the velocity field in the water while the metal ball drops at a constant speed? I would calculate myself the limiting velocity and just input it as an initial condition (i.e. I'm not looking for COMSOL to solve kinematics, just want to get the effect on the fluid due to the movement of the ball). Can I do this with the basic multiphysics package or do I need additional modules? Does the fluid dynamics implementation in COMSOL require an active flow (like in a pipe for example)? And does it take into account interactions between the boundaries and the fluid?
If COMSOL can not do it then can anybody suggest a framework in which is possible to compute a solution to my problem?
Thanks a lot!
1 Reply Last Post 19 ott 2011, 12:00 CEST
Posted: 1 decade ago 19 ott 2011, 12:00 CEST
Check the doc on "FSI" Fluid Structure Interactions in the CFD module.
From what I understand of your demand the answer is rather yes, it takes some time to set up such complex models, and to validate them, but I believe its fully possible ;)
But its also worth to ask directly to your COMSOL rep, here you are on the "users" side :)
Hi Check the doc on "FSI" Fluid Structure Interactions in the CFD module. From what I understand of your demand the answer is rather yes, it takes some time to set up such complex models, and to validate them, but I believe its fully possible ;) But its also worth to ask directly to your COMSOL rep, here you are on the "users" side :) -- Good luck Ivar
