History can not be erased, comsol complains about wrong number of func arguments
Hello, I had a function x1 with 1 argument. I have then changed this function to have 3 arguments, and updated every node in the geometry tree which used this function. COMSOL still keeps complaining about 'function called with wrong number of arguments', even though I tried to clear the history, restart comsol, etc. When exporting the model as a .java file, there are run(), run2(), run3() functions in the java class. All but the last of these contain the old code (x1 called with 1 argument). How can I erase this history? Thank you Daniel
2 Replies Last Post 3 apr 2019, 03:45 GMT-4
Posted: 7 years ago 2 apr 2019, 10:36 GMT-4
I don't think that history is the problem - it's only used when you export the model to a .java- or .m-file, not when solving the model. Are you sure that you have updated all references to x1? Searching for all references using Ctrl+F should do the trick.
If all else fails I think that you should consider contacting COMSOL support.
I don't think that history is the problem - it's only used when you export the model to a .java- or .m-file, not when solving the model. Are you sure that you have updated all references to x1? Searching for all references using Ctrl+F should do the trick. If all else fails I think that you should consider contacting COMSOL support.
Posted: 7 years ago 3 apr 2019, 03:45 GMT-4
You were right, there was a smart Ball selection which used this function to position the center of the ball. Sorry.
