5 ott 2011, 06:21 CEST
If i understood right, I think you need not to export file to define properties.
Is that for phase change and fluid flow?
First, you can use effective heat capacity method directly in comsol for melting
then,
add laminar flow study to marangoni effect.
Add carman-kozeny approximation in volume force term and weak contribution for surface tension effect
best regrads.
then,
best regrads.
5 ott 2011, 10:54 CEST
sir,
thank you for your reply
the problem i am facing is how can i select only a particular nodes(which are greater than the melting temperature) as fluid and solve for the fluid equations in that domain alone... can i define the whole geometry as fluid(assuming solid to be a high viscous fluid) and then solve for heat transfer and fluid flow equations.
Earlier reply will be very useful 4 our progress
Thank u in advance
Karti Keyan
sir,
Thank u in advance
Karti Keyan
5 ott 2011, 15:56 CEST
You mean
"Fluid flow in only molten region"
right?
The whole region is considered as liquid.
Firstly, you should solve phase transition with "heat transfer module" by effective heat capacity method
In that way, you can define liquid volume fraction which range from 0 to 1. (1 for liquid, 0 for solid)
Then, you want to see the velocity profile only in molten region( fl=1), right?
Therefore you need to "porosity method" with "laminar flow module"
You can easily find the paper related to porosity method in google,
in brief, porosity=0 for solid, porosity=1 for liquid.
It can be defined in volume force term in "laminar flow module"
Fx = -C*((1-fl)^2)/(fl^3+b)*u
Fy = -C*((1-fl)^2)/(fl^3+b)*v+rho*g*beta*(T-Tinf)
fl : liquid volume fraction
C : sufficiently large number (ex) 1e12
b : constant for not divided by zero (ex) 1e-3
rho : density
g : gravity
This equation makes velocity zero in solid.
best regards
You mean
right?
rho : density
g : gravity
best regards
9 years ago
17 giu 2016, 17:31 CEST
Hi JiYoung Park ,
is there a possibility to contact you in pm. I just started my Phd and have to do a CFD Simulation of a laser welding process taking into account all effects you described above. Somehow does my program not converge for the laminar flow case, but works well with a k-e turbulent model. I am quite sure that all physics parameters and bc are ok, but have the feeling, that I have to optimize the solver (conditions). Will really appriciate your help!
Best regards from Germany
Antoni
Hi JiYoung Park ,
Antoni
