                                3 ott 2011, 09:07 GMT-4
you have forgotten to tell us which physics you are using, as that aslo might differentiate the frames
normally all overlap, but in "CFD" with "ale" they will all be distinguished and mostly will differ. In "solid" the spatial frame will differ from the material = mesh. For solid see it as the spatial is the deformed shape (initial + deformation u,v,w), while the reference frame is the initial shape.
Test it out: take a cube (default 1m^3), in 3D solid, stationary, give it a material property not too stiff rho = 1[kg/m^3], nu = 1/3 E = 10[Pa], add a gravity volumetric/body force (Total Force) of solid.rho*1[m/s^2], fixe one side/boundary, solve.
 => then define 2 Model Coupling Integration on the domain one on the Spatial frame, one on the Reference frame and solve the volume integration of "1" to get the volume of each.
The results, the reference volume is the initial volume, the spatial is the deformed, mostly greater
This way of decoupling by default the Spatial (x,y,z) from the Reference and Material (X,Y,Z) frame is new in v4 as is worth some careful thinking. It is basically to get CFD and Structural/Solid to look similar as its in fact two ways of looking at the same problem, with two different habit's coming from History, the story of Lagrangian and Eulerian  reference frames, the one flowing with the deformation/fluid and the one onbserving from the shore ... (if that helps, take a look at
en.wikipedia.org/wiki/Lagrangian_and_Eulerian_specification_of_the_flow_field ).
In this way COMSOL is pushing us to unify physics, which is of great help (in my view) when we mix all the physics.
The only exception I know about in COMSOL is the PZT material Elasticity tensor where COMSOL uses the pzt IEEE convention that differs from the usual "solid/structural" convention for the Elasticity matrix (in index ordering, be aware !!)
With the Deformed Geometry (but not the ALE) approach you need to dissociate also the Mesh frame (Xm,Ym,Zm) adding another level
So by now you should have some better clues what too choose, it all depends what you want to do ...
And why not use COMSOL to create the default pairs for you, check the corresponding tick boxes on the Geometry Assembly tab page, and check which Frame COMSOL uses ;)
This way of decoupling by default the Spatial (x,y,z) from the Reference and Material (X,Y,Z) frame is new in v4 as is worth some careful thinking. It is basically to get CFD and Structural/Solid to look similar as its in fact two ways of looking at the same problem, with two different habit's coming from History, the story of Lagrangian and Eulerian  reference frames, the one flowing with the deformation/fluid and the one onbserving from the shore ... (if that helps, take a look at  http://en.wikipedia.org/wiki/Lagrangian_and_Eulerian_specification_of_the_flow_field ).
