MESH
Suppose in my model i have two geometry say a cylinder inside a block. so if i want to apply different mesh to them say finer to cylinder and coarse to block..how should i do???
2 Replies Last Post 19 set 2011, 09:50 GMT-4
Posted: 1 decade ago 19 set 2011, 05:40 GMT-4
add a mesh node (with a right click + select), then select the finer domain, add a size sub-node on the same domain, and leave the second "default" mesh node for the remaining domains
Hi add a mesh node (with a right click + select), then select the finer domain, add a size sub-node on the same domain, and leave the second "default" mesh node for the remaining domains -- Good luck Ivar
Posted: 1 decade ago 19 set 2011, 09:50 GMT-4
hi ,
ivar
thanku.... it actually worked and today after so much of struggle i got my output
hi , ivar thanku.... it actually worked and today after so much of struggle i got my output
