2 set 2011, 09:39 CEST
you can use COMSIOLs time variable 't' to define a time-dependent expression for the heated (cooled) boundaries or domains.
Cheers
Edgar
Cheers
Edgar
2 set 2011, 21:38 CEST
Thanks. Here is the problem:
boundary 1: symmetry
boundary 2: boundary not set |
---------------------- furnace with air |
Silicon wafer | boundary 3||||||| boundary 6
boundary 4: boundary not set |
boundary 5: symmetry
Boundaries 2-4 form the silicon wafer region, while boundaries 1,5,6 form the surrounding furnace region containing air. I want the boundaries 6 to linearly ramp the temperature from T_start to T_end.
Now I'm using Heat Transfer module, with Initial Values1 of both domains (silicon and air) set to be T_start. Then I choose Temperature1 to boundary6, with ramping temperature T0=T_start+ramp_rate*t. Also I set Symmetry1 to boundaries 1&5.
However, I don't know how to set the Surface-to-Surface Radiation part. I chose boundaries 3&6 together, with Radiation direction to be Opacity controlled, Ambient temperature to be T_start, Surface emissivity to be 0.1, and Initial Values of Surface radiosity to be J=0 W/m^2. But when I ran the time dependent study, with Times to be set as "range(0, 1[min], (T_end-T_start)/ramp_rate", I got an error: "Radiation error: exactly one adjacent domain must be opaque. By default all the domains are transparent. Consider right-clicking the node where temperature is defined to add the Opaque subfeature."
By contrast, if I changed the Radiation direction to be either "Positive normal direction" or "Negative normal direction", with Ambient temperature to be Tamb=T_start + ramp_rate*t, I didn't get the error, but the 3D temperature plot showed no temperature at all: the final temperature is T_start everywhere !
Can anyone have any suggestion where is the error (I understand that I need to set up the opaque boundary condition, but I don't know how to set it up...), and how should I ramp up the temperature?
Albert
Albert
