micro pattern on circle
Hi i want to create micro rectangular pattern on circle circumference like the figure in the attached file, i need help regarding this.
3 Replies Last Post 24 dic 2018, 15:19 CET
Posted: 7 years ago 17 dic 2018, 18:05 CET
Hello Usama,
The simplest is probably to use the Rotate feature with a range operator in the Rotation Angle field, see attached file.
Jeff Hiller
Hello Usama, The simplest is probably to use the Rotate feature with a range operator in the Rotation Angle field, see attached file. Best, Jeff
Posted: 7 years ago 24 dic 2018, 09:10 CET
Helloo Dear Jeff. This file is not opening in Comsol 5.3.1 version it need latest version can you please send me this file in the version i have Regards Usama
Posted: 7 years ago 24 dic 2018, 15:19 CET
I cannot offer to post in the Discussion Forum in older versions. Please consider updating to the current version.
Jeff Hiller
I cannot offer to post in the Discussion Forum in older versions. Please consider updating to the current version. Best, Jeff
