divergence of current density
I want to find the divergence of current density using the expression div(J) , where J=(epsilonr-epsilon0)E to find the volume charge density (rho) using continuity equation. => div(J) = d/dt(rho)
if I try to find divergence using standard definition of divergence div(J)=(epsilonr-epsilon0)*(d(Ex,x)+d(Ey,y)+d(Ez,z)) I get large values due some numerical error for the finite mesh element size. Is there any other way to find divergence?
Amin
1 Reply Last Post 13 ago 2011, 14:00 GMT-4
Posted: 1 decade ago 13 ago 2011, 14:00 GMT-4
have you checked if the Exx Eyy ... are not already defined in COMSOL (I tend to forget how it was back in 3.5 ;), then you do not need to use the div() operator. Also check that you use 2nd or higher shape functions
Hi have you checked if the Exx Eyy ... are not already defined in COMSOL (I tend to forget how it was back in 3.5 ;), then you do not need to use the div() operator. Also check that you use 2nd or higher shape functions -- Good luck Ivar
