Adding a layer of Silicon Oxide on top of polysilicon
Hello All,
I am new to Comsol, so this may be a dumb question. I am trying to make a thermal actuator using joule heating. I am trying to apply a layer of silicon dioxide on top of polysilicon. I do this by creating a work plane on top of the first layer, and then extruding that work plane. Then I apply the material to the domain that i just created by extruding the work plane. However, when ever I try this I get the following error:
Failed to find a solution. Segregated Step 1 Singular matrix.
There are 968 void equations (empty rows in matrix) for the variable comp1.V. at coordinates: (1,-5,1.5), (1,-5,2), (1,-3,2), (1,-3,1.5), (1,-2,1.5), ... and similarly for the degrees of freedom (empty columns in matrix). In Segregated Step 1: Returned solution is not converged. Not all parameter steps returned.
I'm not really sure what that error means. Additionally, if I set the material of the second layer to polysilicon instead of silicon dioxide (making both layers polysilicon), the error dissapears. I don't know why this is. The file is attached to this post.
0 Replies Last Post 27 nov 2018, 09:10 CET
Hello George Alphonse
