Hello Myounggon Kim
5 dic 2011, 19:11 CET
I have hard time using particle tracing,
without mass in particle tracing is fine,
but if I put the mass on particle tracing,
the streamline(particle) itself, doesn't move at all,
I don't know the reason why,
I am using comsol 3.5 also, Multiphysics in fluid mechaincs in steady state condition
and I think there are not a lot of example regarding particle tracing,
if someone does have some,
I will be happy if someone shares with me,
thanks a lot have a great day :)
BEFORE ALL Update your COMSOL to 4.2a
then
-Check that plot is based on the right solution.
-Increase time in your transient time study.
-Add particle initial velocity (same as boundary u, v)
-Check particle mass
[QUOTE]
[/QUOTE]
then
26 apr 2012, 15:06 CEST
I want to calculate the particle trajectory resulted from fluid flow in a magnetic field based on the following equation:
m*dV/dT= a*dB/dx+ b(V-u)
where B, u and V are magnetic flux density, fluid velocity and particle velocity.
I have simulated the magnetic field (mf) and flow field (laminar flow, spf).
to calculate the trajectories, I have added "Particle tracing for AC/DC" physics and included a "force" node in it.
My question is:
How should I write the right hand side of above equation in the force node?
Can I write:
dB/dx= d(mf.normB,x)
V-u=d(qx,t)-u
Thank you in advance
My question is:
Can I write:
V-u=d(qx,t)-u
