battery cycling
I competely copy the Capacity Fade 1d model in the case base except the dimension is 3D, but it reports error: error:No consistent initial value found The last time step does not converge
And one sub question is how does the end voltage of ch/disch (just one value input) works as the condition of a plane? Does the average value solved of the plane compare with the setting value? Or it must fails when solving a 3D model of the cell cycling using the charging/discharging cycling boundary condition?(a wrong use)
0 Replies Last Post 23 ott 2018, 13:59 CEST
Hello Ruoyu Xiong
