convergence issues in cojugate heat transfer problem
Posted 15 lug 2011, 02:20 CEST Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Mesh, Studies & Solvers 9 Replies
I am trying to solve a conjugate fluid flow and heat transfer problem. The problem has a channel with fluid flowing through it and surrounding media which has some heat sources.
I am having issues when I increase the inlet velocity. Everything is laminar as it is a microchannel. As the inlet velocity is increased the solution fails to convergence.
I have tried including the results from lower velocity as initial condition for higher velocity but that is still not helping in convergence.
Any suggestion will be highly appreciated.
Sumeet
Nagi Elabbasi
Veryst Engineering
I agree that Peclet number is > 1. The objective of the study is to capture the effect as Pe increases. Do you have suggestion for numerical stabilization? I have been trying iterative solver and increasing the factor in error estimate but that is still not working.
Thank you,
Sumeet
Nagi Elabbasi
Veryst Engineering
I saw your reply to another problem, I hope you have some solution to my problem too. I'm modeling conjugate Heat Transfer problem too. It is periodic segment of cooling channel of gas turbine blade. with one rib on top and one at the bottom (staggered). When i give small i/p velocity it runs OK, but if I increase, it wont converge. let me know how I can solve this problem....
Thank you Very much for your Help in Advance
Raju
Try the same things I mentioned above and also check that Reynold’s number is not too high. Also try temporarily reducing the complexity of the problem by solving the fluid flow problem and then using that known velocity/pressure solution for the heat transfer problem.
Nagi Elabbasi
Veryst Engineering
I'm just wondering, you asked me to solve fluid flow first and introduce heat transfer later. To do this step I store the initial flow analysis solution by going to the menu Solve --> Solver manager and in this menu I click on store solution tab and select current solution at the intial value region, am I right?!.
Thank you
Raju
I am sure there are several ways to do that. The way I do it is through the Study node, Solver Configuration, Dependent Variables. In the first line I change the “Defined by study step” to User defined. Then I go to the sub-node with the individual variables and unselect the “solve for this field” for those I don’t want solved. Then in a duplicate Study node, I do the opposite and set Method equal to the previous solution in “Values of Variables Not Solved For” and in “Initial values of Variables Solved For”.
If that is not clear you can check the COMSOL examples. The peristaltic pump example (Model ID 985) does something very similar.
Nagi Elabbasi
Veryst Engineering
I will try as per your advice...
Regards
Raju
I'm modelling heat transfer in porous media couple with darcy flow module.
The goal of this simulation is investigating the influence of peclet number to the heat transfer result.
I read your comments in this thread but I don't understand how to obtain the numerical peclet number (Pe>1).
In my calculation, the Pe number always has a very large value (1e4 ~ 1e7).
Could you please advice me against this matter?
Thank you,
JN
Suggested Content
- BLOG Course: Modeling Electromagnetic Coils in COMSOL®
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
- FORUM Heat Transfer in Solids Convergence Issues
- FORUM heat transfer / convergence problem
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling?
