Conversion of parametric surface to solid
Posted 13 lug 2011, 02:50 GMT-4 Geometry Version 4.2a, Version 5.2 6 Replies
I built a parametric surface in Comsol 4.2 and am now trying to convert it to a solid. If I use the "Convert to Solid"-function the whole object vanishes without an error message. Do I somehow have to close the open boundary of the surface, or am I doing something else wrong?
The model file is attached.
Christian
Try the "Geometry - right click - Conversions - Convert to Solid".
By the way you do not need the union in this case, so long the loop is closed its OK
i'm trying to convert a surface geometry to a solid (Geometry - right click - Conversions - Convert to Solid) and every time the following message appear :
"The operation resulted in an empty geometry."
i want to understand why this message appear; please help me to find a solution to this problem.
Best regards
Here is some information and tips for converting nonsolid geometries to solids.
Firstly, a surface cannot be converted to a solid unless it is a closed solid; otherwise, that operation results in an empty geometry.
Also, you cannot convert curves or lines in 3D into a solid directly, but if the curves or lines form a closed curve and that curve lie in a plane, then you can form a surface that you can extrude into a 3D solid. To do so, add a work plane in the same plane as the closed curve, and then, under the Plane Geometry node, add a Cross Section node to make the closed curve appear as a closed curve in the 2D Plane Geometry, where you can then use a Convert to Solid node to convert it into a 2D solid (that is, a 3D surface).
A nonclosed 2D surface can be converted to a solid using extrusion so that it gets a nonzero thickness. With the Design Module, there is also a Thicken feature that can thicken a surface into a (thin) solid.
The problem in the parametric_surface geometry is that the topology is invalid (due to self-intersecting curves). If you use two Parametric Surface nodes instead, with the same settings except that in the first one, the s1 parameter runs from 0 to pi, and in the other, it runs from pi to 2*pi (instead of one parametric surface where s1 runs the full circle from 0 to 2*pi). With that modification, and an active work plane with the bottom surface, you can form a 3D solid using a Convert to Solid node with all three surfaces as the input. With the CAD Import Module, you can use a Cap Faces feature to create a closed surface instead of creating a closing bottom surface in a work plane.
For the TopoBoundary model, the closed 2D curve can be directly converted to a 2D solid using a Convert to Solid node in the latest version of COMSOL Multiphysics, version 5.2a, as well as in version 5.2.
Magnus Ringh, COMSOL
Suggested Content
- KNOWLEDGE BASE Repairing the LiveLink Interface Using the COMSOL Installer
- BLOG Modeling Surface Reactions in Porous Media and Reactive Pellet Beds
- KNOWLEDGE BASE Error: Failed to compute elastoplastic strain variables
- BLOG NREL Enhances Biofuel Conversion Processes with Simulation
- FORUM Conversion Of Parametric Surface To Solid
