Deformed surface area calculation
Is there is any way to calculate the surface area of build geometry after deformation (for example, the change in surface area in piezoelectric material after simulation).
1 Reply Last Post 29 ago 2018, 17:16 CEST
Mickaël Barsive COMSOL Employee
Posted: 7 years ago 29 ago 2018, 17:16 CEST
You could use the "Coupling operator">"Integration" in "Definitions" node using as frame "Spatial (x,y,z)". Then in the study node, you should select "Include geometrical non-linearities". To evaluate the area, use the "Derived values" node in "Results" then use "Global evaluation" and set in "Expression": intop1(1)
I hope this helps.
For more details, please contact COMSOL technical support.
Mickaël
Hello, You could use the "Coupling operator">"Integration" in "Definitions" node using as frame "Spatial (x,y,z)". Then in the study node, you should select "Include geometrical non-linearities". To evaluate the area, use the "Derived values" node in "Results" then use "Global evaluation" and set in "Expression": intop1(1) I hope this helps. For more details, please contact COMSOL technical support. Mickaël
