Charged particle tracing in combination with a changing electric field
Hi, I would like to combine a charged particle tracing with an evolving electric field between two plates. The issue I have, is that I have no idea how to implement an electric field as a function of time to distract the particle inside of the capacitor.
Any suggestions or ideas to simulate it in a proper way?
Best Dennis
3 Replies Last Post 21 ago 2018, 15:01 CEST
Posted: 7 years ago 20 ago 2018, 09:43 CEST
COMSOL software supports t variable as time.
So, if you want to consider a value as a function of time,
  1. setup function in Definitions > Functions
  2. use the function(function name) in a boundary condition you want
If you use Piecewise function, Function name is pw1 by default, and you can setup pw1(t) in boundary condition.
Thanks. Kim
Hi, COMSOL software supports **t** variable as time. So, if you want to consider a value as a function of time, 1. setup function in Definitions > Functions 2. use the function(function name) in a boundary condition you want If you use Piecewise function, Function name is **pw1** by default, and you can setup **pw1(t)** in boundary condition. Thanks. Kim
Posted: 7 years ago 20 ago 2018, 14:57 CEST
Hi, thanks a lot! I implanted the Piecewise function, but i can't see any sweep in the study and when I add the Electrostatic Physics interface to the time dependent step in my study I get an error : "Failed to find consistent initial values. Last time step is not converged.".
Thanks in advance, Dennis
Hi, thanks a lot! I implanted the Piecewise function, but i can't see any sweep in the study and when I add the Electrostatic Physics interface to the time dependent step in my study I get an error : "Failed to find consistent initial values. Last time step is not converged.". Thanks in advance, Dennis
Posted: 7 years ago 21 ago 2018, 15:01 CEST
Okay, I solved the problem. The piecewise function worked perfect, but I had to add the Electrostatic Physics interface to the time dependent step in my study and for this combination the absolute tolerance in the time-dependent solver was to low and couldn't converged. For higher tolerances and bigger time steps everything is working fine!
>Hi, >thanks a lot! I implanted the Piecewise function, but i can't see any sweep in the study and when I add the Electrostatic Physics interface to the time dependent step in my study I get an error : >"Failed to find consistent initial values. >Last time step is not converged.". > >Thanks in advance, >Dennis Okay, I solved the problem. The piecewise function worked perfect, but I had to add the Electrostatic Physics interface to the time dependent step in my study and for this combination the absolute tolerance in the time-dependent solver was to low and couldn't converged. For higher tolerances and bigger time steps everything is working fine!
