How to connect particle trace module with the electrical circuit?
I want to connect particle trace module with the electrical circuit for an application. Could you please guide me for it?
2 Replies Last Post 3 set 2018, 03:19 GMT-4
Posted: 6 years ago 3 set 2018, 00:31 GMT-4
hi krupali, have you get any solution beause i am also doing the same
Mickaël Barsive COMSOL Employee
Posted: 6 years ago 3 set 2018, 03:19 GMT-4
Are you using the particle tracing interface with the "Electrostatic" interface (or "Electric Current")?
If yes, you can use the "Terminal" node to connect the Eletric interface with "Electrical Circuit" interface.
For more help, please contact the COMSOL technical support.
Mickaël
Hello, Are you using the particle tracing interface with the "Electrostatic" interface (or "Electric Current")? If yes, you can use the "Terminal" node to connect the Eletric interface with "Electrical Circuit" interface. For more help, please contact the COMSOL technical support. Mickaël
