Jeff Hiller
COMSOL Employee
24 giu 2011, 18:53 CEST
Without seeing your file, it's hard to say. Can you post it?
My wild guess: your geometry may be drawn in meters (that's the default) rather than inches.
24 giu 2011, 20:43 CEST
Jean-Francois,
Thank you for the reply. I measured the edges and they report 1 x 1 x 10 as I intended. I created the geometry via the Draw->Block command.
I am posting the file.
This brings up another problem I had. I initially brought the geometry (a 1" x 1" x 10" block) in through the Solidworks interface. The grid showed in meters, depicting the geometry as approximately .025m x .025m x .250m. I got funky results. When I measured the edges, they were .0508" x .0508" x .5080". This was a Solidworks 2010 model.
I am also posting the simple CAD Import problem.
Regards
Frank
Jean-Francois,
Regards
Frank
Jeff Hiller
COMSOL Employee
24 giu 2011, 22:24 CEST
It looks like the load in the file you sent is set not to 1e4[psi] but to 1e4[(in.lb/s^2)/in^2]. Once you set it to 1e4[psi] you get the expected result.
The doubling of dimensions is something that I remember hearing about a while back and which I believed was fixed since. Have you tested this on the current version, 4.2?
24 giu 2011, 22:43 CEST
Jean-Francois,
I see. Thank you.
How can I input a total load on a boundary, without having to calculate the x-sectional area?
In many cases one knows the total force readily, and would simply like to impose a boundary condition of that force over that arbitrary area.
Frank
Jean-Francois,
I see. Thank you.
Frank
Jeff Hiller
COMSOL Employee
25 giu 2011, 00:43 CEST
In v3.5a, you can have the software compute the surface area for you by way of an integration coupling variable. It's a bit clunky, but it works.
In v4.2, you have the option of providing the total force and the software does the rest for you, see screen shot.
