Modal Analysis contact issues and Material specifications
I am currently working on a modal analysis of a pipe within a pipe. The modal is fairly simple, two long, concentric cylindrical pipes, constrained at the top, subject to only a body load.
My first issue is establishing contact pairs. I set it up so that the outside surface of the inner pipe is not able to cross through the inside surface of the outer pipe, yet, when I run the analysis I still get modes where the interior pipe passes through the exterior pipe. Any thought?
Also, I have another model of the same system, except for this time I place a small rubber seal in between the two pipes, close to the top. I can get the model to run if I keep all of the components the same material (i.e. model the seal as steel just like the two pipes) but, when I try to change the seal material to a rubber the model is not able to run giving an error:
Undefined value found.
- Detail: Undefined value found in the stiffness matrix.
There are 30 equations giving NaN/Inf in the matrix rows for the variable mod1.u
at coordinates
Any input would be greatly appreciated.
0 Replies Last Post 16 giu 2011, 17:42 CEST
Hello Danielle Lower
