Any good ideas: point dipole on dielectric surface: Solver does not find a solution
Posted 14 giu 2011, 09:45 CEST Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1 1 Reply
Hello all,
I am learning COMSOL 4.1 and I reached a point where I am stuck.
I am trying to model the following scene in a3D geometry with the COMSOL electrostatics package:
A sphere of dielectric material A is placed on a substrate. Inside the sphere I place an electric point dipole.
The substrate B is dielectric, too, and has a thin surface layer C with a different dielectric constant. On top of the surface, surrounding the sphere is air. The substrate has a imaginary component of the dielectric constant.
I have made the substrate approx. 100 times larger than the sphere to aprox. infinity. Ultimately, I want to integrate over E^2 (E=electric field) in the absorbing dielectric substrate), but first I need to find the potential.
Now my problem is that beside the initial values I cannot change any other properties of the Electrostatics parameters. The boundary conditions seem to be "locked". Charge conservation is applied to all domains and for the E field COMSOL uses the constitutive relation of the relative permittivity. Zero charge applies to all outer boundaries and I cannot change it.
As a result I do not know what to change or how to approach the problem when the solver fails. I tried changing the mesh size, but that did not help.
How would you proceed?
Many Thanks for any suggestions!
james
PS:
I have attached the COMSOL file in case you are interested.
james
PS:
1 Reply Last Post 14 giu 2011, 20:32 CEST
