Heat transfer from LIQUID to SOLID
Posted 11 giu 2011, 07:13 CEST 0 Replies
I have a simple set up where hot air is flowing into a metal cylinder with a closed end. There are two hole at the side walls near the end of this cylinder, these are for the outlet. Whatever I do, I don't seem to have heat transfer from hot air to this metal cylinder.
When I set air cooler then the metal, I do get heat transfer. But not vice versa...
Any help would be greatly appreciated, thank you in advance
Dogan Sinar
Hello Dogan Sinar
