7 giu 2011, 22:39 CEST
What's your expression for the initial value? If it's a function respect with the space coordinate, you should use capital letter instead of lowercase one when ale is involved. For example, init (X), not init(x)
8 giu 2011, 20:32 CEST
Amazing! It works. Thanks a lot. But may I ask why?
Is it mentioned somewhere in the manual? Do I have to use upper cases of coordinates in boundary conditions, governing equations, or the moving velocity of ALE?
9 giu 2011, 09:55 CEST
check the doc about "Frames" that is important to catch the subtle differences, otherwise you will have "great" suprises ;)
in v4 you have basicall "spatial", "material" and "mesh" Frames.
They start all overlapped and accessed by a lower case x,y,z.
Then depending on the physics they "split" hence upper and lower cases (lower case for spatial, upper case for material and mesh,
with ALE the mesh splits off too, hence x,y,z and X,Y,Z, and Xm,Ym...
16 apr 2014, 00:39 CEST
hello,
does a init(r,z) also work in a 2D axisym problem?
or should it be a init(R,Z) definition?
init(x,y) is well plotted in the function definition, but I am not able to use it as initial values of my domain.
lukas
found the problem... meters and millimeters init(r*1000,z*1000) did it.
hello,
lukas
