Small signal analysis of an inductor
Does anyone has a working version of the tutorial
- Small signal analysis of an inductor
for Comsol 4.0 or higher ?
2 Replies Last Post 27 mag 2011, 07:41 GMT-4
Posted: 1 decade ago 26 mag 2011, 09:45 GMT-4
I attached here a trial for a "Small-Signal Analysis of an Inductor" with Comsol 4.1.
I followed the tutorial for 3.5 but I only calculate the inductance for one value of the bias current.
-The bias point is obtained from a stationary solution.
-Then a time-harmonic simulation of the linearized model is superimposed on the stationary solution.
The inductance should be between 0.2 and 0.22 but I obtained 0.0093.
Any idea ?
I attached here a trial for a "Small-Signal Analysis of an Inductor" with Comsol 4.1. I followed the tutorial for 3.5 but I only calculate the inductance for one value of the bias current. -The bias point is obtained from a stationary solution. -Then a time-harmonic simulation of the linearized model is superimposed on the stationary solution. The inductance should be between 0.2 and 0.22 but I obtained 0.0093. Any idea ?
Posted: 1 decade ago 27 mag 2011, 07:41 GMT-4
I attached here a improved version for a "Small-Signal Analysis of an Inductor" with Comsol 4.1.
I think that the initial conditions for the linearized time-harmonic simulation are correctly set up but for a subtle reason the inductance calculation is incorrect.
Can anyone have a look ?
L. Queval
I attached here a improved version for a "Small-Signal Analysis of an Inductor" with Comsol 4.1. -The bias point is obtained from a stationary solution. -Then a time-harmonic simulation of the linearized model is superimposed on the stationary solution. I think that the initial conditions for the linearized time-harmonic simulation are correctly set up but for a subtle reason the inductance calculation is incorrect. Can anyone have a look ? -- L. Queval
