25 mag 2011, 14:15 CEST
Isa,
did you assign a unit to your Sawtooth function? It should be unitless for your application.
Cheers
Edgar
Isa,
Cheers
Edgar
25 mag 2011, 14:41 CEST
thank-you Edgar.
No, I define it simply. But when I plot it, as title appears "F1Saw(t)", so it seems that by default it takes the variable time, doesn't it?
How should I do it?
Thanks again in advance.
Isa
thank-you Edgar.
How should I do it?
Isa
26 mag 2011, 16:43 CEST
Sorry I still didn't received Comsol 4.2 but with 4.1 I set up a model with a triangle function multiplied by Jc.
26 mag 2011, 17:55 CEST
Dear Loic,
Thank-you very much for your help!
I have opened your file in both, comsol 4.1 and 4.2, and yes, you are right, it allows me to introduce the external current density as "Jc*tria1(t)" but you can see that it put itself in orange colour (in both versions), which points out that it is "unexpectd unit of input"... It is like a warning, not an error because later the program runs.
I think it is because tria1(t) has units of "seconds", do you know if we can do it unitless?
Thanks in advance!
Isa
Dear Loic,
Thanks in advance!
Isa
27 mag 2011, 06:07 CEST
I don't know if it is possible to do it unitless but as you said, it is a warning not an error. Comsol is just saying that he cannot determine it automatically.
27 mag 2011, 08:50 CEST
Ok. Understood.
Again, thank-you!
Isa
Ok. Understood.
Again, thank-you!
Isa
27 mag 2011, 08:59 CEST
Isa,
you might consider to define a constant with an appropriate unit, assign the value 1 and multiply with your function to remove the unit issue.
Cheers Edgar
Isa,
Cheers Edgar
Sven Friedel
COMSOL Employee
27 mag 2011, 10:17 CEST
the correct way calling a time function *without orange* marks is:
sawtooth(t[1/s])[A/m^2]
The [1/s] removes the unit [s] and creates a unitless input for the function call.
The [A/m^2] adds the correct unit required for the entry field.
Sven
Sven
27 mag 2011, 10:56 CEST
Dear Sven,
I have tried your suggestion and, obviously (it makes sense), it has worked!
Thank-you very much!
Isa
Dear Sven,
Isa
