question in the blood vessel tutorial
In the attached tutorial, on page 15, the force (boundary load) in the x,y,z directions is specified with a negative sign. I am wondering if someone can explain what the negative sign signifies. I am asking because when I look under the fluid properties, the stress vectors are defined as spf.T_stressx , spf.T_stressy and spf.T_stressz and not -spf.T_stressx,-spf.T_stressy and -spf.T_stressz.
Thanks for the help.
Sirisha
6 Replies Last Post 10 mag 2016, 11:10 CEST
Posted: 1 decade ago 25 mag 2011, 18:10 CEST
Posted: 1 decade ago 27 gen 2012, 13:50 CET
I am also involved in implementing the similar problem. I also want to have clarification especially when implementing such relation to other problems.
Hi, I am also involved in implementing the similar problem. I also want to have clarification especially when implementing such relation to other problems. Thanks
Posted: 1 decade ago 29 gen 2012, 21:23 CET
The minus sign is because the traction or force per unit area on the solid surfaces is the negative of the same quantity on the matching fluid surfaces.
Nagi Elabbasi
Veryst Engineering
The minus sign is because the traction or force per unit area on the solid surfaces is the negative of the same quantity on the matching fluid surfaces. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 29 dic 2012, 09:05 CET
I think the the stress (spf.T_stressx , spf.T_stressy and spf.T_stressz ) is acted on the fluid , while the force acted on the artery walls is -spf.T_stressx , -spf.T_stressy and -spf.T_stressz. They are a pair of acting force and reacting force.
Posted: 9 years ago 7 dic 2015, 18:41 CET
in (r,z) coordinate system, these would be spf.T_stressr , spf.T_stressz right?
Posted: 9 years ago 10 mag 2016, 11:10 CEST
www.comsol.com/blogs/how-do-i-compute-lift-and-drag/;
May this will help you , the minus sign would represent the force to "the fluid", if integral the force to the wall or boundary , "(spf.T_stressx , spf.T_stressy and spf.T_stressz )" would be the right choice.
https://www.comsol.com/blogs/how-do-i-compute-lift-and-drag/; May this will help you , the minus sign would represent the force to "the fluid", if integral the force to the wall or boundary , "(spf.T_stressx , spf.T_stressy and spf.T_stressz )" would be the right choice.
