modeling thin film heaters at the interface of 2 materials
Posted 16 mag 2011, 01:16 GMT-4 Low-Frequency Electromagnetics, Geometry, Materials, Mesh Version 3.5a, Version 4.0, Version 4.0a, Version 4.1, Version 4.2 2 Replies
So I am not sure what is the best way to model a thin film heater (say around 1 micron) at the interface of 2 materials (each around a mm thick). I tried using surface heat flux option but that does not work because apparently the solver has to know how much gets divided into the 2 domains.
The problem with adding an extra thin layer of volumetric heat generating material is that the meshing becomes really complicated.
Any suggestion will be highly appreciated.
Sumeet
Hello Sumeet Kumar
