Same model, different results
Hello, I am relatively new to COMSOL and am trying to run a study to see if there will be harmonic motion in my model. When I run the time-dependent study with the time being range(0,.01,4)[ms], I see some good harmonic motion. When I run it at range(0,.01,8)[ms], the harmonic motion is not there anymore (even in the 0 to 4 ms range where it showed up earlier). Nothing in the model changes. The only difference is a longer range of study. Why would this cause my solution to have completely different results?
1 Reply Last Post 18 mag 2018, 18:16 CEST
Posted: 7 years ago 18 mag 2018, 18:16 CEST
Hi Josh,
Short answer: It's because the initial time step taken by the solver depends on the final time you give.
Long answer, see: https://www.comsol.com/forum/thread/108101/time-dependent-temperature?last=2016-03-31T06:37:28Z
Jeff Hiller
Hi Josh, Short answer: It's because the initial time step taken by the solver depends on the final time you give. Long answer, see: https://www.comsol.com/forum/thread/108101/time-dependent-temperature?last=2016-03-31T06:37:28Z Best, Jeff
