How to simulate 3D open channel turbulent flow with free surface
I want to simulate open channel flow with free surface.
I don't know what kind of physical interface can be used to simulate it.
Moving mesh?
Gas-liquid 2 phase flow?
Fluid-structure coupling?
PDE mode?
CFD module?
thanks
3 Replies Last Post 12 ago 2011, 04:54 GMT-4
Hello Tamotsu Nakandakari
Posted: 1 decade ago 6 giu 2011, 14:50 GMT-4
Hei,
I am working on the same kind of problem, did you find a solution?
Hei, I am working on the same kind of problem, did you find a solution?
Posted: 1 decade ago 6 giu 2011, 20:13 GMT-4
No, I didn't.
But I got some advise from Japanese customer center.
Moving mesh and PDE are basically used.
CFD is needed in the case of turbulant flow analysis.
Multiphase flow (air-liquid) is no need.
To use PDE, we have to prepare the governing equations that describe the flow we want to analyze.
I don't know how to set Moving mesh.
Please refer to attach file.
Hi, No, I didn't. But I got some advise from Japanese customer center. Moving mesh and PDE are basically used. CFD is needed in the case of turbulant flow analysis. Multiphase flow (air-liquid) is no need. To use PDE, we have to prepare the governing equations that describe the flow we want to analyze. I don't know how to set Moving mesh. Please refer to attach file.
Atish Surana COMSOL Employee
Posted: 1 decade ago 12 ago 2011, 04:54 GMT-4
Can someone comment on how can a water flow (with given volumetric flow & pressure) in an open surface irrigation canal be modeled?
