Atmospheric Pressure Corona Discharge in Air
Hello everybody,
I have a problem with the tutorial "Atmospheric Pressure Corona Discharge in Air". The highvoltage potential is -45kV at the inner cathode. When I change the highvoltage potential to +45kV the solution for the electrons/pos. ions/neg. ions density doesn't make sense. At first I try +45kV with the same surface reactions. Then I modify the surface reactions a little bit but this has no impact to the solution. Does anyone have the same problem?
Best regards
1 Reply Last Post 20 apr 2018, 08:05 GMT-4
Johannes Gräwer COMSOL Employee
Posted: 8 years ago 20 apr 2018, 08:05 GMT-4
Dear phil,
if your COMSOL license is on subscription, you can submit your questions via the Support Center for a comprehensive response from our Technical Support team.
Best Regards, Johannes Gräwer
Dear phil, if your COMSOL license is on subscription, you can submit your questions via the [Support Center](https://www.comsol.com/support) for a comprehensive response from our Technical Support team. Best Regards, Johannes Gräwer
