Geometric optimization v4.1
Posted 26 apr 2011, 09:09 GMT-4 2 Replies
I would like to find the optimum geometry of my structure in v4.1, but I have some problems.
I have - as a simple example - a beam in a 3D model. The thickness and the length of the beam are global parameters. I used the "Piezoelectric Devices interface" to clamp the two side of the beam and to apply a pressure on the upper boundary. I would like to find the optimum thickness (of a defined interval) to get a maximal deflection of the beam. I can do it with a parametric sweep, but I would like to use the optimization module as the model will get more complicated.
I set the point objective as the deflection and the global control variable as the thickness. COMSOL returnes the initial value of control variable as result. The geometry did not change. Do I have to define the parameter for thickness in a different way?
Has anyone examples for geometry optimization?
Thank you very much!
2 Replies Last Post 2 mag 2011, 12:13 GMT-4
