transient heat transfer. Electric circuit with magnetic field ????
Posted 29 mar 2018, 08:02 GMT-4 Electromagnetics, Electromagnetic Heating, Low-Frequency Electromagnetics Version 5.3 1 Reply
Hello everybody,
I am facing a problem with my model, which is a flyback converter.
I initially solved the transformer model, using electric circuit and magnetic field under transient analysis. The model is boundary pulse voltage excited. I got the results after reaching cvasistationary condition.
Now I am trying to simulate transient heat transfer (ht in solids). I've put the bc accordingly, the heat source being the Joule heating for the the coils, and natural convection for external bc, the base being insulated. I also try to get the initial values from the previous study (I defined another Time dependent study for ht). The problem is that it doesn't work, it stated something about undefined value of comp1.T, which should be something about not defining correctly a bc in ht interface, I solved this part, but then I get something about undefined comp1.cir.pulse, which should be something related to the pulse voltage of the electric circuit, right?
I don't think that the heat transfer interface should be coupled with the electric current (as I saw in  the application library models) or should it be? Does anyone have an ideea of what the issue might be?
Please help !!!
Thank you in advanced!
