Re-use time-dependent flow field outside of solved time window
Posted 23 mar 2018, 21:15 GMT-4 Computational Fluid Dynamics (CFD), Studies & Solvers Version 5.3a 0 Replies
Hi all,
I'm trying to model a simple reactor with a stir bar and chemical reactions happening on the reactor surface. I can solve for both the time-dependent flow field and concentration gradients of key reactants and products as a function of time. However, the flow field calculation is relatively quite expensive (~5 minutes to solve for only a few seconds of stir bar rotation, as compared to ~10 seconds for concentration gradients).
I want to model the concentration gradients over several hours, so I don't want to have to solve for the flow field over such a long time scale. The flow field is periodic (once the stir bar has completed one rotation, the flow field looks equivalent to t = 0). Is there a way repeatedly use these values in a study for the concentration gradient?
I don't want to use the trick where I make a new study and use the final time concentration values as the initial condition for the next study, because that will require a ton of studies to get the full several hours window.
I feel like i'm missing something simple.
Thanks for the help!
Hello Anthony Abel
