Sum parametric sweep solutions
I am using Particle tracing module and a Parametric sweep to compute the final position of a set of nanoparticles depending on their initial position. After that, I would like to sum all the partial solutions, but doing it one by one through "Data Sets->Join" is kind of tiresome.
Can you give me some advise of how could I do it?
Thank you very much!
3 Replies Last Post 8 mar 2018, 11:16 GMT-5
Posted: 8 years ago 6 mar 2018, 16:18 GMT-5
Juan,
check this blog contribution: https://www.comsol.de/blogs/using-the-previous-solution-operator-in-transient-modeling/
A similar approach also works for parametric sweeps and for summing or do other things along a sweep.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Juan, check this blog contribution: https://www.comsol.de/blogs/using-the-previous-solution-operator-in-transient-modeling/ A similar approach also works for parametric sweeps and for summing or do other things along a sweep. Cheers Edgar
Posted: 8 years ago 8 mar 2018, 07:02 GMT-5
Hello Edgar,
Thank you very much for your answer. Unfortunately, I was not able to implement the method that is described in that post. For the moment I am using the following algorithm:
sum(withsol('sol1',variable,setind(parameter,i),setval(t,t_0)),i,1,xx)
It is slow, but it works. I will try to give a second chance to the other method.
Juan
Hello Edgar, Thank you very much for your answer. Unfortunately, I was not able to implement the method that is described in that post. For the moment I am using the following algorithm: sum(withsol('sol1',variable,setind(parameter,i),setval(t,t_0)),i,1,xx) It is slow, but it works. I will try to give a second chance to the other method. Juan
Posted: 8 years ago 8 mar 2018, 11:16 GMT-5
I think that you should consider using the Combine Solutions study step.
