Impedance boundary condition
HI,
I am modelling a simple semiconductor resistance using the RF module of Comsol 3.5 to study its behavior at frequencies in the tera-hertz regime. I would like to extract the impedance from the S parameters. The geometry i have used is a cuboid having dimension 1mm x 1mm x 2.5mm(x x y x z). I have used the impedance boundary condition at the semiconductor-air interfaces (for the boundaries along the x-z and y-z planes) and specified the port boundary condition for the boundaries along the x-y planes . But i seem to get results which are totally against my thinking.
I am doubtful of what to specify as the source electric field in the impedance boundary condition.... I think that's where i am going wrong.... or is it really something else?
Can someone help me in this regard???
1 Reply Last Post 15 apr 2011, 08:02 CEST
Posted: 1 decade ago 15 apr 2011, 08:02 CEST
are you sure you are respecting the minimum mesh criteria: a few mesh elements (if possible >5) per wavelength IN THE MATERIAL (include the index in your estimation, not the free space wavelength) ?
I believe that is your main issue here
Hi are you sure you are respecting the minimum mesh criteria: a few mesh elements (if possible >5) per wavelength IN THE MATERIAL (include the index in your estimation, not the free space wavelength) ? I believe that is your main issue here -- Good luck Ivar
