10 apr 2011, 19:22 CEST
I haven't looked at your file yet, but did you define the Contact pair between the right boundaries. By the looks of it the contact isn't defined properly and the bodies are penetrating into each other, hence causing the mesh to deform too much
10 apr 2011, 23:56 CEST
Normally you apply a displacement or a force on one of the solid bodies, and prescribe the displacements of the ALE to follow the u,v of the deformed solids.
You are imposing a displacement on part of the ALE, on top of the contact. And do not forget that the symmetry condition in the solids must also have an equivalent in the ALE (there is no symmetry, you must block the x motion in the symmetry plane in your case
Check out a few of the examples of large deformations and contacts in the model library. Then I'm sure you will get the BC better defined
By the way, why not drop the ALE to start with and look at the deformation with a scale of "1". I do not really see why you need it, at least until you get your contact case running. Another hint use small steps such as a range(0,0.1,10)
12 apr 2011, 11:49 CEST
Thank You Ivar,
do you know if, in order to find it´s better to use a small range step?
Did COMSOL use, to find out the solution at steo i, the solution at the step i-1 ?
Thank You Ivar,
12 apr 2011, 15:08 CEST
its always better to use "small" steps to allow the solver to follow its optimum, but not smaller than required, that means that sometimes 1 step is enough ;)
12 ott 2011, 19:58 CEST
Can anybody send me a very basic implementation of ALE like shrinking of a circle or square with time. I am trying to implement ALE without any physics (for simplification). But I am not seeing the desired result. I just get back the initial geometry. I don't know what mistake I am making.
Sanket
Sanket
9 mag 2012, 15:01 CEST
Hello Giulio,
I tried to run your .mph file but i don't see any convergence problems ! ! ! Are you worried because the total displacement computed of 0.01 [µm] is much bigger than the prescribed one of 4.10^-7 x 1[nm]???
According to what Ivar told you, what kind of changes did you make to make it work better? could you upload the final file please?
Hello Giulio,
