Problem with temperature dependent viscosity
I am trying to model a simple glass furnace using Incompressible navier-stokes and heat transfer modules of COMSOL 3.5a.
As I proceeded further on my model, to make it more physically realistic, I added a temperature dependent viscosity term and enabled convective heat transfer. My viscosity values are based on the VFT relation, and for the type of glass that I am using, I entered a value as follows:
10^(-2.49474+(4099.768/(T[1/K]-544.0237)))[Pa*s]
This causes "negative inside sqrt" error either during calculation of various expressions or the residual term, depending on the type of solver that I use, whenever I enable convective heating.
When I disable convective heat transfer, the solver seems to work fine but gets stuck at certain times and I observe convergence value getting bigger and bigger at those times. When I give a constant value for viscosity (5-10-20-30), the bigger viscosity I give, the less problematic the convergence becomes during solver operation.
Has anyone faced with a similar problem? Any help would be greatly appreciated.
PS: One of my colleagues suggested that I should change my time unit from seconds to minutes or even hours, as glass processes are slow in real life. I do not know how to do that in COMSOL as well.
7 Replies Last Post 14 set 2011, 13:06 CEST
Posted: 1 decade ago 8 apr 2011, 10:49 CEST
For the time constant, in 3.5 there is normally a time multiplier, setting it to 60 means default min, 3600 default hours, but I find it easier to use units (at least in V4 you have min, hour, day, year) and just make "t" largeer
Hi For the time constant, in 3.5 there is normally a time multiplier, setting it to 60 means default min, 3600 default hours, but I find it easier to use units (at least in V4 you have min, hour, day, year) and just make "t" largeer -- Good luck Ivar
Posted: 1 decade ago 8 apr 2011, 10:55 CEST
hi, thanks for your fast reply. where can i find this time multiplier?
Posted: 1 decade ago 8 apr 2011, 11:54 CEST
Sorry I cannot find it back, 3.5 is getting old ;) I could not find it either in the doc,. maybe it was/is a application mode specific expression/parameter.
Anyhow what works OK by using t=2[day] or t=36[hour] in both 3.5 and 4.
Hi Sorry I cannot find it back, 3.5 is getting old ;) I could not find it either in the doc,. maybe it was/is a application mode specific expression/parameter. Anyhow what works OK by using t=2[day] or t=36[hour] in both 3.5 and 4. -- Good luck Ivar
Posted: 1 decade ago 11 apr 2011, 13:48 CEST
thank you, my model works OK now.
Posted: 1 decade ago 24 mag 2011, 21:41 CEST
Please can you explain how do you change the "t" unit ? I have the same error and I don't find how change the time unit. Thank you
Gaelle
Please can you explain how do you change the "t" unit ? I have the same error and I don't find how change the time unit. Thank you Gaelle
Posted: 1 decade ago 14 set 2011, 12:58 CEST
I am searching this thing and now found it. Thank you so much Ivar.
Best regards.
[QUOTE] Hi Sorry I cannot find it back, 3.5 is getting old ;) I could not find it either in the doc,. maybe it was/is a application mode specific expression/parameter. Anyhow what works OK by using t=2[day] or t=36[hour] in both 3.5 and 4. -- Good luck Ivar [/QUOTE] I am searching this thing and now found it. Thank you so much Ivar. Best regards.
Posted: 1 decade ago 14 set 2011, 13:06 CEST
Gaelle
I changed time unit by this way, normally (default) time unit is second, now when I want to set up time to solve is minute, hour, day, year... I setup time like this: 3[min] or 5[d] or 8[h]... etc
For example: when the time unit is default, I type time like this (in the quotation mark): Times: "range(0,0.1,120)" second
Now: I can type: Times: "range(0,0.1,2[min])" second.
Hope you can find out what you need.
[QUOTE] Please can you explain how do you change the "t" unit ? I have the same error and I don't find how change the time unit. Thank you Gaelle [/QUOTE] I changed time unit by this way, normally (default) time unit is second, now when I want to set up time to solve is minute, hour, day, year... I setup time like this: 3[min] or 5[d] or 8[h]... etc For example: when the time unit is default, I type time like this (in the quotation mark): Times: "range(0,0.1,120)" second Now: I can type: Times: "range(0,0.1,2[min])" second. Hope you can find out what you need.
