Heat Pipe-Thermal Energy Exchanger
Heat pipe is a very efficient way to transfer thermal energy from one end to another. It works on the principles of thermal conductivity and phase transfer. The High thermal conductivity enables a it to transfer and dissipate heat to the desired location through a “capillary action”. This effect is similar to placing a paper tissue in a fluid and observes the fluid rise up the paper towel. Heat pipes were invented by Los Alamos National Laboratory in 1963 by George Grover to supply heat to and remove waste heat from energy conversion system. Actual working A heat pipe is a copper tube with an internal wick structure that is sealed on both the ends with a small amount of water or ammonia liquid inside. The wick is used to transport the liquid from one end to other. As heat is applied to the hotter side of a pipe, the water will boil and turn to a gas which then travels with the thermal energy to the colder end of the pipe where it condenses back to a liquid. This process is known as capillary action. This cycle is repeated continuously to remove heat from a system. Modern heat pipes are able to transfer heat several hundred times faster than a solid copper rod. Based on material used to design and area of application there are various types of heat pipes are available in the market. Types of Heat Pipes • Vapour chamber or flat heat pipes • Variable conductance heat pipes • Diode heat pipes • Thermosyphones • Loop heat pipes Applications of Heat Pipes
Today, Heat pipes are used in a variety of applications from space to handheld devices that fit in your packet. Some applications are listed below • Spacecraft • Computer systems • Solar thermal • Permafrost cooling • Cooking appliances • Ventilations and heat recovery nuclear power conversation For more info about heat pipe
Thanks, Rajesh Kharche +91 - 20 - 24 321 770
0 Replies Last Post 11 gen 2018, 00:35 GMT-5
Hello Rajesh Kharche
