Maximum over time - at operator, point/line evaluation
Posted 21 nov 2017, 08:56 GMT-5 General, Parameters, Variables, & Functions, Results & Visualization Version 5.3 1 Reply
Hi all
I've done a Parametric Sweep and I'm trying to Evaluate a Line or set of Points at a time instant corresponding to a maximum of a variable, mfh.By. This time instant is dependent on the solution.
When I evaluate (Point Evaluation) the expression "at(attimemax(0, 0.25, mfh.By,t),mfh.By)" it gives me this error:
The solution specification is nonscalar or out of range. - Operator: at - Geometry: geom2 - Domain: 2 Failed to evaluate expression. - Expression: at(attimemax(0,0.25,comp1.mfh.By,t),comp1.mfh.By) Failed to evaluate expression. - Expression: at(attimemax(0,0.25,comp1.mfh.By,t),comp1.mfh.By)
Also, I find "Geometry: geom2" weird because I only have Geometry 1.
However when I evaluate the arguments of the "at" operator separately, they are evaluated with no problem. The same if I put them on an expression in a Point Graph.
Also, I have a Cut Point 2D Data Set over which I'm evaluating, which has more than one point (five) in a line with different x-coordinates. When I evaluate, the different points are different columns. Is there anyway I can put them in rows, so than I can plot the Table Graph in as a function of x? Or another way to do this?
Thank you
