Undefined value found in the equation residual vector
Posted 16 nov 2017, 11:50 GMT-5 Fluid & Heat, Computational Fluid Dynamics (CFD), Bioengineering Version 5.3 0 Replies
The below post is related to an archived discussion
Feature: Stationary Solver 1 (sol2/s1) Undefined value found. - Detail: Undefined value found in the equation residual vector. There are 11000 degrees of freedom giving NaN/Inf in the vector for the variable comp1.u_solid. at coordinates: (745.454,-285.843), (745.429,-285.848), (745.405,-285.853), (745.378,-285.859), (745.351,-285.864), ... There are 11000 degrees of freedom giving NaN/Inf in the vector for the variable comp1.v_solid. at coordinates: (745.454,-285.843), (745.429,-285.848), (745.405,-285.853), (745.378,-285.859), (745.351,-285.864), ...
I've been facing this issue of late. My geometry is a bit abnormal since I'm modelling the heart, I'm drawing the outline from a confocal microscopy image using illustrator, exporting as dxf and then importing it through the geometry import tool. I've given all the necessary properties, but I'm unable to understand this error regarding my geometry. Any help is much appreciated.
Hello Srinath Ramkumar
