DEP force in liquids
Posted 2 nov 2017, 15:10 CET Low-Frequency Electromagnetics, Computational Fluid Dynamics (CFD), Studies & Solvers Version 5.2a 1 Reply
I am trying to calculate the DEP force on a water drop in order to study its deformation. For the water drop I use "Moving mesh/Phase Field" interface and for the electric field "Electrostatics".
I introduce the force as a "Volume force" node in the CFD module as Kd(es.Ex,x), being K a constant, but everytime this error appears:
"The following feature has encountered a problem: Failed to find consistent initial values. Last time step is not converged."
I tried with EP force instead of DEP just to check (an arbitrary charge times the electric field) and in this case everything is fine.
Could anybody give me some clue about what I am doing wrong?
Thank you very much!
