[solved]using displacement of a point as a variable
I am solving a time-dependent study and I would like to use the instant displacement of a point as a variable for electric potential. I know that the displacement along x,y,z is u,v,w. But I only need one point. How can I achieve this? ( I tried to define a point and use "point.u" but does not work)
1 Reply Last Post 1 nov 2017, 09:28 GMT-4
Posted: 8 years ago 1 nov 2017, 09:28 GMT-4
Updated: 8 years ago 1 nov 2017, 10:37 GMT-4
Hello Guanglu,
You can use a component coupling of the integration type for this. This is because integrating a continuous field at one point is the same as picking its value at that point. I am attaching a toy model where an integration component coupling is used to link the voltage on a boundary to the displacement at one point.
Jeff Hiller
Hello Guanglu, You can use a component coupling of the integration type for this. This is because integrating a continuous field at one point is the same as picking its value at that point. I am attaching a toy model where an integration component coupling is used to link the voltage on a boundary to the displacement at one point. Best, Jeff
