HELICAL COIL
I did helical coil simulation in 2D Axial Symmetry. I got coil inductance and coil resistance but the problem is when i check the simulated results with practical results(Using LRC meter) simulation not even showing the near value. I am attaching my simulation results and My coil diagram. Can any one please help me. I am struck with this simulation. . Hope you understand my request.
Thanks a lot.
3 Replies Last Post 23 mar 2011, 07:42 CET
Posted: 1 decade ago 22 mar 2011, 07:57 CET
you have missed a few things there: 2D axi is only valid in r>0 (right side of the vertical axis, and you are not looking down the coil axis, its the vertical axis "z" in 2D-axi.
Check the doc to better understand which plane you should work on and how it projects
Hi you have missed a few things there: 2D axi is only valid in r>0 (right side of the vertical axis, and you are not looking down the coil axis, its the vertical axis "z" in 2D-axi. Check the doc to better understand which plane you should work on and how it projects -- Good luck Ivar
Posted: 1 decade ago 22 mar 2011, 11:49 CET
Hi Ivar,
I am doing same kind of simulation in 3D. I am following the example power inductor. I am passing AC current through the coil. I am getting some errors when i am solving. Can any body suggest me some way how to solve errors(some examples). I am attaching my coil. My model file is too big so i can't able to attach but you can download from this link(rapidshare.com/files/453800179/10-turns.mph). Hope you understand my request.
Thanks a lot .
Hi Ivar, I am doing same kind of simulation in 3D. I am following the example power inductor. I am passing AC current through the coil. I am getting some errors when i am solving. Can any body suggest me some way how to solve errors(some examples). I am attaching my coil. My model file is too big so i can't able to attach but you can download from this link(http://rapidshare.com/files/453800179/10-turns.mph). Hope you understand my request. Thanks a lot .
Posted: 1 decade ago 23 mar 2011, 07:42 CET
to upload your files, clean them from the solution and the mesh:
File - Clear Mesh, Clear Solution, Reset History
in early v4 they where not all there, then right click the first "size" node in the mesh and do a Build selected
the in the Solver Configuration node, right click and CLEAR solution (do NOT DELETE)
Hi to upload your files, clean them from the solution and the mesh: File - Clear Mesh, Clear Solution, Reset History in early v4 they where not all there, then right click the first "size" node in the mesh and do a Build selected the in the Solver Configuration node, right click and CLEAR solution (do NOT DELETE) -- Good luck Ivar
